Dinette table/cushions
den1jen
Member Posts: 42
We decided to upgrade just the foam in our cushions 1st; we went with a combination of 2" firm Qualux and 1" medium Qualux glued to the firm and will say so much better. The other mod we decided to try is removing the laguna table and mounting system. I built a prototype table that collapses down when not in use, so it doesn't take up any room and opens up the area.
1st photo the table is put away and can see the tabletops (~16" x 22") and (~8" x 22") The small one can be used for say morning coffee (I had extra wood LOL). I am thinking of building an extension to extend the depth of the larger table to 19 or 20". Due to the way I built the table legs the tabletop is not wide enough to place on the supports on the sides, I need to make them wider so can use the tabletop as bed support as well.
2023 Tab 400 BD
2023 Ram 1500 crew cab
2
