Fuses
Sebastian
Member Posts: 25
Need to remove fuse for TV, Red light indicates problem. Was plugged into outside electric under clam shell.
@Sebastian, do you have a question? Turn the big battery disconnect to Off, pull out the fuse, and push a new one in. The fact it was connected to AC is not real relevant, the converter turns that into 12v DC for the TV and radio.1
