Nothing on when connected to shore power
I am connected to 30 amp shore power and I have nothing coming on
  • Gomers2
    Gomers2 Member Posts: 172
    Need a little more information. This is at home? At a campsite? Breakers are switched on at the pedestal? Are you using any type of surge protector /voltage regulator between the pedestal and the cable? Does the LED on the camper power cable light up? Did you check the breakers inside the camper on the power converter?
  • Gomers2
    edited May 17
    Comment deleted (sorry I was not reading carefully). See Mod's recommendations below
    qhumberd Administrator, Moderator Posts: 917
    @Westies247 Welcome and a few tips on posting. First the year and model of your T@B is helpful to other members wanting to help. For power issues There are a lot of possibilities, so let us know what you have checked that works (or doesn't) along with what situation you are in (home, camping or on the road)
    And when needed, pictures can make all the difference!
    Good luck
