Alde 3020 noise
First time using my camper in high altitude, 8000'.
The heater is making a noise that find of sounds like crunching a granola bar, and crazier than that you can hear it move through the system.
Any ideas?
Haven't heard it described as "crunching a granola bar" but it's a well known symptom of running the Alde at high elevation/lower oxygen levels. The older 3 way fridges with gas mode do that too, and even the stove might be a little noisier with less consistent flame.
Assuming you have the Alde set to propane fuel source . . .
Set the Alde to 'High Altitude' mode. That will increase the combustion fan speed providing more O2 to the burner for a quieter and cleaner propane burn.The noise of moving glycol means there is some air in the system. The 3020 has an automatic air bleeder so with time the air will be removed and the fluid movement noise will stop. However, do make sure the Alde Glycol tank has fluid to be drawn into the system.
For my TAB fluid movement noise tenses to occur after towing on rougher roads but changes in air pressure might be a factor as well.
Adventures: 50 Nights: 415 Towing Miles 50,6500 -
ChuckieG, welcome to the Forums. We really need to know what exact year your trailer is for a proper answer. If you have a trailer with the Alde 3010, the "Alde Freight Train" noise was a real thing, and there are long threads about it.
If you have a trailer from around 2018 and on, you might have the Alde 3020 or an Alde 3030. Those Aldes have a "High Elevation" setting that takes care of the noise. If you have one of these units, just check your manual and look for that little "Mountain" symbol in the menus.
And, I always wonder "what was Alde thinking" when they built a system that was such a "clunker" at the "high elevation" of 3000 feet!
I'm wondering if I should install an expansion tank to help remove any air bubbles.
Any thoughts?
The newest Alde install manual below seems to address this, and it might take care of the noise. Anyone have one of these accumulator tanks in their install? I know some have used such a tank to dampen the water pump noise
I finally figured it out!
After finding the expansion tank in the rear wall, I topped it off (it was a bit low) and turned on the furnace. The fluid inside the expansion tank developed so much turbulence in it (not from air) that it was making all that noisy I was talking about. The circulation pump at the furnace was turned up all the way, I reset it to level 2 and now it's quiet as a mouse.
2
