2013 T@B Little Guy-damaged grey water tank?
When I returned from camping this weekend I noticed something hanging from the base of my T@b camper. It appears to be connected to my grey water tank.
  • Grumpy_G
    Grumpy_G Member Posts: 789
    Affirmative. There are (or should be) two metal brackets that hook around the edge of the tank right where the rust stains are.
    Where is this thing exactly? The tank itself is pretty hard plastic. Under the shower area there is a cover for the shower trap that is a metal rectangle, but the shape and position of what is "dangling" appears wrong.
    Have you crawled under there to see what you can see?
    MuttonChops Member Posts: 2,087
    Yep, as @Grumpy_G noted the metal brackets have failed.
    That is the Gray Water Tank . . . not something connected to it 😉
    Your 2013 should be about the same as this picture :
