FOR SALE - - 2019 T@B 320 S Boondock Lite - $20,500 (Tucson, AZ)
Bayliss
Bayliss Member Posts: 1,534
CONTACT INFO: Greg, via private message through this forum, E-mail (gg18022@gmail.com), or by phone at (520)-308-5571.
Original owner. Non-smoker and no pets. Meticulously maintained, includes several valuable upgrades and is adventure ready. Very clean, inside and out. Alde heating, electrical, and plumbing systems all function as designed. Camper has been waxed annually, so the exterior finish looks great. Has always been stored under a roofed facility and covered with a “Classic Accessories” Perma Pro fitted RV cover. The attached photos accurately depict its appearance and condition. If desired, the exterior decals can be easily removed with a hair dryer. (Details included below photos).
(Truck Not Included 🤣)
GG02 - 2019 TAB 320 S (09-28-2026).jpeg GG03 - 2019 TAB 320 S (09-28-2026).jpeg GG04 - 2019 TAB 320 S (09-28-2026).jpeg GG05 - 2019 TAB 320 S (09-28-2026).jpg GG06 - 2019 TAB 320 S (09-28-2026).jpg GG07 - 2019 TAB 320 S (09-28-2026).jpg GG08 - 2019 TAB 320 S (09-28-2026).jpeg GG09 - 2019 TAB 320 S (09-28-2026).jpeg GG10 - 2019 TAB 320 S (09-28-2026).jpeg GG11 - 2019 TAB 320 S (09-28-2026).jpeg GG12 - 2019 TAB 320 S (09-28-2026).jpeg GG13 - 2019 TAB 320 S (09-28-2026).jpeg GG14 - 2019 TAB 320 S (09-28-2026).jpeg GG15 - 2019 TAB 320 S (09-28-2026).jpeg GG16 - 2019 TAB 320 S (09-28-2026).jpeg GG17 - 2019 TAB 320 S (09-28-2026).jpeg GG18 - 2019 TAB 320 S (09-28-2026).jpeg GG19 - 2019 TAB 320 S (09-28-2026).jpeg GG21 - 2019 TAB 320 S (09-28-2026).jpeg GG22 - 2019 TAB 320 S (09-28-2026).jpeg GG23 - 2019 TAB 320 S (09-28-2026).jpeg GG24 - 2019 TAB 320 S (09-28-2026).jpeg GG25 - 2019 TAB 320 S (09-28-2026).jpeg GG26 - 2019 TAB 320 S (09-28-2026).jpeg GG29 - 2019 TAB 320 S (09-28-2026).jpg
(TV Antenna with Magnetic Mount - - Pole Not Included)
GG30 - 2019 TAB 320 S (09-28-2026).jpg GG31 - 2019 TAB 320 S (09-28-2026).jpg
(Kitchen Sink "HepvO" Waterless Waste Valve - - replaced original P-trap)
(Diamond Plate Air Conditioner Cover - Closed)
(Diamond Plate Air Conditioner Cover - Open)
("Renogy" 100W Portable Solar Suitcase)
GG34 - 2019 TAB 320 S (09-28-2026).jpg GG35 - 2019 TAB 320 S (09-28-2026).jpg
INCLUDED UPGRADES:
  • “Goodyear” Endurance ST225/75R15 tires and full-size spare.
  • “Isotherm” Cruise 65 Elegance AC/DC refrigerator.
  • “Battle Born” 100 Ah LiFePO4 lithium battery.
  • “Progressive Dynamics” Inteli-Power PD4135KW2B lithium-capable electrical power management center/converter with surge protection (hard-wired installation).
  • “Victron” BMV-712 Smart battery monitor with 500A/50mV current shunt with digital wall display monitor and Bluetooth connection via Victron mobile app.
  • “Victron” SmartSolar MPPT 75/15 solar controller.
  • “RVLock v4.5” electronic door lock (includes set of standard lock keys and two electronic key fob remotes - - can also be unlocked using an owner-set private 5-digit code using the included key pad).
  • “Proven Industries” (2178-A) heavy duty coupler lock and tow-chain storage, including heavy-duty keyed puck lock (includes set of keys).
  • Upgraded (larger capacity) nuCamp aluminum storage tub on Boondock platform - - modified to provide secure storage of two 20 lb. propane tanks.
  • “Doty Hill” sun visor (black - - attaches to camper’s Keder rail - - see included photo).
  • nuCamp spare tire mount attached to front aluminum storage tub.
  • “TireTracker” (TT-600) wireless trailer tire pressure and temperature monitoring system with windshield mounted digital monitor display. Includes four tire sensors (two for trailer tire use and two extras) that screw on to tire valve stems. A wireless signal enhancer/extender is hard-wired inside the camper cabin. Easy set-up.
  • “Valterra” sewer hose storage tube secured to front frame of trailer for easy access.
  • “King” Omni Go omnidirectional (OA1501) television antenna with magnetic mount and coaxial cable (see photo) - - NOTE: extension pole depicted in included photo (adjustable painter’s pole) not included.
  • Kitchen sink “HepvO” waterless waste drain valve (cabinet space saver - - replaced standard “P-trap”).
  • “Dometic” Ultra Breeze (U1400BLS) roof vent cover with bug screen.
  • “Enhanced Performance Systems” (EPS) black diamond-plate external air conditioner cover with bug screen.
INCLUDED ITEMS:
  • Owner manuals and associated diagrams (e.g., electrical wiring diagram).
  • Original standard equipment (Boondock package, TV, radio/stereo, air conditioner, outside shower, “Lagun” adjustable table, including interior and exterior (passenger side) mounts. Power disconnect switches have been added to the TV and radio/stereo electrical wiring to prevent phantom battery power drain when they are not in use.
  • ”Camco” 25’ RV fresh-water hose.
  • “Camco” RV fresh-water tank filler with pressure-sealed “on/off” valve.
  • “Valterra” fresh-water pressure reducer (45-50 PSI) and 90-degree elbow plumbing attachment.
  • “Rhino” 15’ sewer hose.
  • “Camco” SideWinder 20' expandable RV sewer hose support.
  • “Camco” Swivel Stik RV black-water holding tank rinser with flexible extension.
  • “Ramble” Lego-type leveling blocks (x9).
  • RV tire chock blocks (x2).
  • “Ox Blox” RV jack tube heavy-duty support block.
  • RV jack tube metal foot plate with metal safety pin.
  • Tongue jack single wheel poly caster (rotates and is removable).
  • “Croft” (TJWK10-S) pneumatic dual wheel kit for tongue jack (rubber tires - - rotates and is removable).
  • 20 lb. propane tank (propane included).
  • Black spare tire cover with adjustable tightening strap.
  • Black tire covers (x2).
  • “Trimax” (TCL75) wheel chock type anti-theft lock (includes set of barrel-type keys).
  • “Trimax” (SXTC-2) hitch coupler yoke lock (includes set of barrel-type keys).
  • “Trimax” (SXT-5) hitch pin lock (includes set of barrel-type keys).
  • 30-amp OEM power cord.
  • 30-amp reduction to 20-amp electrical “dog bone” cord.
  • 50-amp reduction to 30-amp electrical “dog bone” cord.
  • 30-amp reduction to 15-amp electrical plug adapter.
  • “Puck Lights” (x2) - - installed inside front platform aluminum tub and passenger side rear storage compartment (tap “on/off”; each light is powered by 3 AAA batteries).
Plus, miscellaneous handy storage/organizational modifications for everyday necessities strategically placed throughout the camper cabin interior (e.g., two three-prong wall coat/hat hangers; cell phone storage; TV/Radio remote storage; magazine/small book/maps storage; eyeglass holders located for easy access and protection; tissue box holder; toiletries and other bathroom supplies hanging organizer (hangs on inside of wet bath/shower door); under-cabinet napkin holder; spice rack with integrated paper towel holder; one of the three upper rear cabinets modified to provide routing of electrical power cord to nearby wall outlet for easy CPAP device placement and use, and secure routing of airway hose, if needed/desired (otherwise, the cabinet remains available for any type of storage).
Greg & Marlene (Tucson, AZ)
