Water and pump
Dana
Member Posts: 65
Wondering a couple of things…..
- TAB 320CS, 2021. Dry camping, tank full. Turn pump on, then faucets to get pressure and water. Do I have to do that with the outdoor shower also? I never use that……
- I left the pump on after pressuring faucets on this last trip. Turns on when I turn on a faucet, off when I shut off a faucet. When water got low the pump turned on by itself so I shut it off so it wouldn't burn out. Is it supposed to do that? Leave pump on or off?
Thanks,
Dana
Best Answers
- I typically purge the air from the outdoor shower lines when de-winterizing. This allows the pump to pressurize the system faster.
- These water pumps have a pressure switch that shuts the pump off when the shutoff pressure is reached (generally around 40 psi). I generally leave the pump on when in the trailer and off when I leave in the trailer. If a leak occurs with the pressurized system it won't result in the pump pumping all the water out the leak. If the pump draws in air instead of water from a low tank, it can't pressurize the system to its shutoff pressure and will run continuously.
Rich2019 T@b 400
The Shurflo pump manual explains that the pumps are designed to run "dry". There are many stories that discuss a pump running for hours with no major ill effects.
Towed by 2014 Touareg TDi2
