AC tab 360
I just read you can run the AC with the electric kw set to off and that it will keep the heat from coming when room temp is below desired setting. Has anyone done this?
Answers
Not sure I understand your question. What exactly are you wanting to accomplish?
Thanks
Moderator
Hi, If using the AC and you do not need the Alde for either heat or hot water, setting it to 0 Kw (0 ,1 or 2 are the options) will ensure the Alde does not turn on and generate any heat when running the AC in Alde auto mode.
Some overlapping can occur if the setpoints for the Alde and Saphire AC are set too close to each other allowing a small of heat produced if the Alde is set not to 0Kw. This is also partially a result of the sensors being in two separate locations. The Alde sensor is up high inside the Alde control panel, while the Saphire sensor is located low near the return air vent of the AC. The temperature difference between the high and low locations contribute to the issue.
2025 360 CS
Southern Maryland2
