Black tank exit pipe leak
RxRick
Member Posts: 6
2015 Tab 320
Take at look at this thread on repair and see if it helps:
Thank you. That seems to be my problem. When I pulled on the drain valve I discovered the drain pipe moves freely, broken loose from the bottom of the tank.
