TAB 400 Alde system filled with antifreeze despite filling with bypass engaged
Hi,
I am new to RV's, and purchased a 2018 TAB 400 this summer. I'm trying to winterize.
The camper did not come with the "manual" to do winterizing. I've viewed some videos and the closest one I can find is the "Travels with Delaney" video...the plumbing inside their plumbing access door looks most similar to mine.
I followed the directions laid out by him.
When I get to the step where I switch the bypass handle vertical (to "bypass"), I'm under the assumption that the Alde system water heater is bypassed, and I can proceed with pumping antifreeze into the rest of the system.
HOWEVER, when I disconnect my water pump inlet (that goes into the water storage tank) and then put the inlet into my gallon of antifreeze, it pumps and pumps. I pumped in two gallons and it STILL would not stop pumping. I was worried something was wrong as Delaney said it should be way less than a gallon.
I suspected I was filling up the Alde heater. My 2018 has three drain valves right by the plumbing door, and a yellow handle flap valve deeper inside. When I flipped the yellow handle flapper valve, pink antifreeze came out. THe yellow handle flapper valve is connected to the Alde heater.
What is wrong?
In looking at the bypass valve as it is plumbed, it appears perhaps the system relies on a couple check valves. Is this so? COuld one of these be bad? I ask because from what I see, unless those big plastic things are check valves, I don't see how bypass would work…
Is there a plumbing schematic I can find somewhere to check on proper plumbing?
Any help appreciated.
Dave (squidtone)
    qhumberd Administrator, Moderator Posts: 913
    edited November 2
    Dave,
    Welcome to the forum and sounds like something got out of order in your procedure, but getting some antifreeze in the hot water tank is not the end of the world. I would flush that out by draining and then running fresh water thru the system till it all gets cleared.
    Then refer to this link (its in the help nucamp support tab above)
    Older 400 winterize
    My 2019 400 bypass looks like this when ready to winterize:
    The unofficial guide attached also has more information on the 2018/2019 era 400s
