What is the best way to keep a stored 820 from freezing without winterizing?
I live in Michigan and like to go camping during the winter months. Wondering what the best way is to keep my lines from freezing while it sits in my driveway, as I will not be winterizing it?
I would winterize.
Then use bottled water as needed for cooking.
Flush toilet with a mixture of antifreeze/water.
On return from winter camping drain black tank and gray tank . . . hot/cold fresh water lines not used.Safest approach IMHO.
I was thinking about plugging in shore power from my house and run the Alde at 1k with 60 degrees set on thermostat. Would that work, or is that a bad idea? Worried if it ever got below zero degrees areas in the camper may freeze. I was also thinking about running a space heater. Looking for some experience and input on best to keep it in the ready but not freeze. Thanks
You can use the "blow out" method of winterizing. Drain the trailer, blow out the lines, and use a little basic RV antifreeze in any of the ordinary traps. Drain the pump. Done.
The only real answer to the question of "do I need to winterize" is generally "yes".
We can show you how to do this with the Nautilus panel, etc.
I did drain the water out of it but did not winterize. On another note, do I turn on the battery heater?
winterize
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0 -
I live across the lake from you in Ontario - I'd definitely winterize and disconnect battery. (Or pull the fuse from the solar controller.)
@Eugene . . . See the trend . . . Winterize is best if not only real approach
The Air Blow Out Method is very simple and fast to do.
nüCamp claims the Cirrus products are four season mainly due to the heated basement. That is when the Alde is on some cabin heat is vented to the storage tank area. That's about it as It's doubtful the real-world sidewall/roof insulation is anywhere near the advertised claims . . very few campers are. So if you don't winterize and run the Alde or other heat source 24/7 at home:
- Your energy bill will be huge (poor insulation)
- If the heat source fails, all your camper water lines will freeze/fail.
- While you are doing the 3-hour freezing day drive to your campsite there will be no Heat in the Cirrus. High risk of freezing.
If your winter camping trip is a few days, the bottle water method works well and is simple.
If you'll be at one spot with reliable power for many days (Alde on 24/7) then you could use the Cirrus water system . . . but would have to at least drain everything before driving back home.As for the Li-Ion Battery Heater, in general:
The battery has a built-in Battery Monitor System [BMS].
When the BMS detects the battery positive terminal voltage above the battery internal voltage, the BMS allows charging If the battery internal temperature is above ~freezing.
When the temperature is below freezing, the BMS (assuming the Cirrus Battery Heater Switch is on) will first heat the battery, then allow the charging to begin. That heating operation uses a bunch of battery energy.Pulling the fuse on the solar panel power source, a best practice for camper winter storage, helps to keep the battery positive terminal at the same voltage as its internal voltage and no charging is started.
Visit the Battery Vendor web-site for specific information.
Adventures: 61 Nights: 417 Towing Miles 51,0500
