Which fuse?
I am going to replace my current battery with a lithium one. I will not be changing any wiring other than adding a victron shunt. Can someone confirm my steps and if the fuses I am looking at are the
correct ones.
  • For the MPPT the fuse is directly below it.
  • For solar panels the fuse is on the green battery line in the front tub with only 1 pos and 1 negative in the right side if the picture..
Steps for install:
  1. Shut down all power at disconnect
  2. Pull the inline fuses
  3. Remove old battery negative line first
  4. Install shunt
  5. Install the New battery positive cables first
  6. Turn on battery disconnect
  7. Install the MPPT fuse first
  8. Wait 1-2 minutes then install solar panel fuse
Thank you in advance
