3Wheels/Tires for nuCamp Tab400 Boondock
3 Camper wheels with mounted Rainer Apex Tires ST235/75R15 from a 2019 NuCamp TAB 400 Boondock, very low mileage. Asking $425 or best offer. Possible delivery within 200 miles of Raleigh NC for $50 gas.
    qhumberd Administrator, Moderator Posts: 915
    @Cybythesea Potential buyers might want to see the manufacture date code on these as well
    the last four digits of the DOT (Department of Transportation) code stamped on the sidewall, showing the week (01–52) and year of manufacture.
    Format: WWYY (first two digits = week of the year; last two digits = last two digits of the year).
    Example: 1023 means the 10th week of 2023 (early March 2023).
    Where to look: Look near the rim on the tire sidewall. Some tires only stamp the full date code on one sidewall, so check the inner sidewall if you don't see four numbers on the outside. (Tires made before 2000 used a three-digit code).
    Trailer tires that have good tread can still age out and should not be used. You would have to consult a tire pro for specifics on the Rainiers.
    Moderator
  • Cybythesea
    Cybythesea Member Posts: 2
    Thank you for the info.
