alde heater noise
is the alde heater supposed to be very loud. No way to use it at night as it makes so much vibration noise loud on the outside also.
  • Nomad
    Nomad Member Posts: 7,209
    What noise exactly are you experiencing? There's two kinds that have been discussed in other threads - A gurgling from the fluid as it passes thru the overflow tank and a roaring noise.
    1 - Can usually be toned down by adjust the flow of the pump
    2 - Usually only occures when camping at higher altitudes 8k or higher. No real fix for this yet.
  • Tabaz
    Tabaz Member Posts: 2,421
    See "Alde Freight Train" thread for more info.  Many of us can't use our Alde at higher elevations because of the loud noise coming from the air intake/exhaust hoses.
    2016 Outback 320
  • Michigan_Mike
    Something else I'd do is pull the outside plastic cover on the Alde vent from the side of the trailer and check to see if you have any insects that have built a nest inside that area.  I noticed a rumble in mine earlier in the spring of this year and that was suggested by the factory as mud wasps often find there way in this area.  I have since installed a screen across the openings of my Alde and hope that this ends that threat.
  • Tabaz
    Trailsnail - what altitude did you experience the loud noise?
    2016 Outback 320
