Installing bamboo floor
Estancio
Member Posts: 243
I have been considering installing bamboo pre-finished hardwood flooring in my T@B. Some of you have installed similar floors, but I cannot seem to find any detailed discussions. The main questions are: Should it be glued to the original vinyl floor? What type nails/fasteners did you use? Any advise would be helpful.
Stancil Campbell
2011 T@B
Rockingham, NC
2011 T@B
Rockingham, NC
Here is the write up I did a few years ago when I installed laminate flooring. It floats, no glue needed. I placed it right over the vinyl, but I would recommend placing the foam padding between the two floors, something I am considering redoing.
http://tab-rv.vanillaforums.com/discussion/comment/4647/#Comment_4647
Sterling, VA1 -
Thanks! Looks like you used nails. Do you recall what size & type of nails?Stancil Campbell
2011 T@B
Rockingham, NC
I used click stop flooring with no nails.0
OK, I will look into that. ThanksStancil Campbell
2011 T@B
Rockingham, NC
Had anyone installed a laminate floor? Did you take the benches out or kitchen cupboards?0
I installed laminate (click stop). Did not remove anything, but added cove molding strip along base instead.0
