Setting Up Checklist Question
gilbutler
Member Posts: 169
Regarding the item: "Attach water hose to city water or (if using water tank make sure large cap is loosened)." What large cap does this refer to and where is it? Thanks for any help.
Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim
I venture to guess they are referring to the opening on the trailer where you will stick said hose. You don't want to attach the hose to the pedestal, open the valve and THEN try and open the stiff flipping big white plastic cover where the hose makes entry to the trailer. They are just saying flip the cover to the open position on the trailer before turning on the flow of water. If you don't your feet and everything around you will be wet while you mess around with the trailer water intake port. Clear as muddy ground water? :-BSally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.
Said white flippy cover to water port on trailer...Sally, "PlaT@Bus" 2016 T@B Sofitel Maxx-S (plata=silver; SP), previously Little Guy 2014 Silver Shadow LE, TV -- 2013 Chevy Avalanche + two hounds.
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
