Drinking water canister replacement
Judy_P_M60
Member Posts: 1
Does anyone know where to buy the tank and replacement flexible tube to the sink. We have a used Tab and this is needing a replace.
What year and model T@B do you have?
The tubing should be obtainable from most any RV dealership. I don't know about the tank as they have changed over the years.
Are they damaged in some way?
Sterling, VA -
Are you referring to the portable 5 gallon tank that was in the older t@b's? I pulled ours out and replaced it with a 10 gallon tank underneath. I can check and see if we still have it. You can have it for shipping cost.
John2007 T@B
Rockford, IL
- 919 Introductions
