What goes on discharge side of 1 1/2" Bristol grey water valve?
Runtarooti
Member Posts: 76
Right now, the outlet flange coming off my grey water valve is short, smooth 1 1/2" ABS pipe, no threads. It's also damaged, and needs to be replaced with something to allow me to discharge to sewer or attach hose to drain and dump. What do I Iook for? Is it glued to the valve or threaded? The valve functions, but I can't drain.
2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback
Got a pic of what yours looks like?
To clarify - valve works but you can't drain <- If you open the valve, gray water comes out? You can't drain because there's nothing to attach a dump hose to? -
Can't drain because nothing to attach a dump hose to.2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback -
Ok, sounds like you just need that fitting - you can get them at most RV places I've been to and they glue on. My gray water broke behind the valve so I needed the valve and the fitting. I just had an RV place do it as I was on the road. Took about 15 minutes as they had all the parts and glue. If you can get the part, it should be easy enough to glue on if you're handy.
Ok, thanks. No RV dealer for 60 miles. Hoping to order the part from CW or Amazon, I have the ABS glue, just don't know what fitting to order. Anxious to go on my Maiden voyage, but these pesky problems keep popping up! I guess I'll go get my tires balanced....what fun!2015 T@B Max CS-S Silver and Black
- 919 Introductions
