Door Hold Solution
Michigan_Mike
Member Posts: 2,858
There has been discussion in the past on holding the trailer door open and this is something a member did earlier and it works fine. This is a simple fix that works and you can cut and bend a piece of metal rod to whatever length you desire, depending on the application. The current door stop is mounted horizontally and if you drill vertical holes through the existing stop assemblies this works great.
2
Thanks Mike - and that was OutbackAZ (I got instructions from him to do this and am very pleased with the results - whenever I put the visor up now, I can still have the door open)!Michele, Tucson, AZ. TV - '13 F150 & '16 T@Bitha special order.
You never really travel alone. The world is full of friends waiting to get to know you!1 -
Thanks Michelle, but I got the idea from Tony on this forum. BTW, make sure you put some tape on the door and T@B where the drill chuck might rub against it.2016 Outback 320
2024 Ford F150 Supercrew short bed.4
