Just FYI on what is under the shower/toilet floor
Matt
Member Posts: 4
Hi,
I just wanted to post a picture of what you have when you remove the shower floor. I had a crack in the shower pan of 2015 T@B Max S I purchased this spring and decided to fix it right by replacing the floor. Feel free to ask any questions about the replacement. Easier than going in blind like I did.
Matt
Matt
7
Thanks Matt! It's helpful to know what's beneath the floor. Removes a bit if the mystery and will good info if a repair is needed!2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota0 -
Thanks for the great pics and info. That explains why the shower floor "gives" a bit when I walk in or out.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Nice! What is the difficulty factor from 1 to 5? And does it damage the shower to remove it?Mark - 2016 T@b Max S (Silver/Red), 2012 F-1500
Nice shot! This would be an excellent time to install one of the SeeLevel ll monitors in the trailer too if you didn't have one.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1
I'll try to answer in order...
Yes, there was only 2 one inch chucks of styrofoam for support next to the shower drain pipe. I framed a new floor in there to firm it up. Still plan on using a wood mat of sorts for protection though.
The 1 to 5 scale...for me was in the middle. Pulled one side of paneling off. There is access to the shower trap underneath. It unscrewed. The toilet flange is threaded and screwed in so that is good to know. Cut the caulking and tap it with a cold chisel and it will start to turn.
Hope that helps!1 -
That is a great idea on the See Level II. I wish I would have checked back in sooner!
