LAGUN Table
So helpful - thanks for the details!hammerstone said:BigBlue,
Nice looking T@B! My table top is 24" x 29 1/2". The 29 1/2" dimension is the same as the factory table top, for fitting it in the space to make the bed; (i added two rails to support it). The Lagun mount is centered in the 24" dimension, and is offset so one side is 6 1/2" from an edge. I've attached a picture that should make it clear, but post or call if you have questions. I decided on the 24" dimension and the location of the mount after cutting a piece of cardboard to the size of the original table, and then trimming it and moving the mount to different locations. Since your trailer may be slightly different than mine, you may give that a try.
