Heating issues in our new 400
JonNLeslie
Member Posts: 20
We have driven from MInneapolis to the most part of Novia Scotia and the 400 has been wounderful except on cold nights in the low forty"s the Alde will only heat the interior to 62 degrees. I believe our settings on the controller are correct and we do get hot water. I tried the tipping forward and backward but had no response.WE will be stopping in Sugar Creek to have them take a look on our way back to Minneapolis. After talking wirh NuCamp the 400 should have heat coming from the back, front, sides and in the bathroom. Does anyone have thoughts on how to correct this problem. It's cold in NOvia Scotia. Thanks
Jon and Leslie Richey
T@B 400 TV 4 ruuner 2016
2018 T@B 400. TV 2016 4 Runner
Minneapolis,MN
In my opinion 62F is perfect for sleeping
Are you running the Alde on propane or shore power electric, or both? The 400 has a larger interior space but it also has more heating elements. Are you getting heat from all of the areas that you mentioned?Jon & Angela | Florissant Colorado | 2017 Outback S -
Could you post a pic of the Alde in menu mode?2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
We just checked with the factory and got this response:
"1. Check the Red dial on the circulation pump found by the Alde Heating System itself underneath the bed, shown in the picture below. It should be turned to 3 (This controls how fast the glycol flows through the convectors)
2. Check the Alde Glycol Level, this can affect how efficient the Alde heating system runs."
Let us know what you find!
Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 400 -
Thank you for the input. The ALDE is on electric. The pump is set on 3-4, the gylcol level is fine and the settings on the thermastat are:
Temp 72
Electric on #2
Pump at THerm
Pump at 4
External starft off
Amps at 20
Minneapolis,MN -
@JonNLeslie I have a 320S and have to set the thermostat at 85' to kick it in, then down to 82' to stay warm. My tabletop thermometer will read in the 60's otherwise. It never gets to the 80's. Hope this helps!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
Thanks for the info. I will give 85 a try and have my flip flops and beach towel ready
Minneapolis,MN -
Also you have to make sure that there are no obstructions for the cold floor air to circulate under the benches all the way to the back where the alde fins are and if your back panel opens up to let max heated air flow out. Small things in the way really make a difference.
As noted in some of the other forum discussions your thermostat might be off and in need of being calibrated. Have you used another digital thermometer to see if there is a difference between it and what the Alde is reading? Heat does rise too and that could fool the Alde thermostat, so maybe you will need to check it for accuracy and keep them sandals and beach towel handy just in case!JonNLeslie said:Thanks for the info. I will give 85 a try and have my flip flops and beach towel ready
- 919 Introductions
