T@B 400 Bathroom door vents?
LSkrabut
Member Posts: 136
Has anyone wondered why the bathroom door on a 400 is not vented for air flow?
We noticed that the humidity is higher (like wet towels) in a closed off area of the bathroom if the door is not left a bit ajar. Also if the door is ajar, the temp is more equal with the rest of the trailer. We have placed a small item (2" square) to keep the door ajar to test this thought out and it seems to be helpful. We do keep the fan vent open for the most part all the time.
So my real question is has anyone drilled holes in the lower and upper part of the door for venting? Thoughts anyone?
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
We use the vent fan in the open position. Removes the moisture quickly. Will also drop the warm temp if cold outside. kind hared to read the closed/ open indicator.
2018 T@B 400, 2017 Nissan Titan Crew cab0 -
We tend only to use the bathroom fan when needed, but the vent stays open all the time.
I still found leaving the door ajar keep the bathroom more on an even keel with the rest of the trailer. Why I asked if anyone vented the door.
Utah Driven
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
