Sidewall tire date
mona
Member Posts: 246
Where exactly is it located on the sidewall?
Jeannie
Jeannie
2015 T@b S Max white with silver trim. 2018 GC Trailhawk.
The below figure shows a typical Manufacture Date Code location.Do not believe the location is regulated to the exact location, as I recall on my tires it is toward the lower right of the Tire Size marking instead of the lower left as shown in figure. Have also read articles stating it is on the inside side wall, not the outside side wall as shown in the figure . . . however all date codes I've seen are on the outside side wall.Image below figure is the actual date code on my T@B tires
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Towed by 2014 Touareg TDi -
Thank you!2015 T@b S Max white with silver trim. 2018 GC Trailhawk.
- 916 Introductions
- 72 Teardrop Groups & Links
