Help re: plumbing/water tank/sink on 2006 T@b 320s
mdomb529
Member Posts: 39
Hi everyone. We just purchased a 2006 T@b 320s. The pamphlet does not give any information on the sink, fresh water tank, or grey water tank. I know there's potentially a lot of variability even among 320s models, but I'm hoping someone who knows what they're talking about re: older models can help me with the following questions:
Best,
Matt
- From what I can tell by crawling around underneath, this camper does not seem to have a city fresh water hookup. Can anyone confirm this?
- The water tank appears to go in with the spout on the top; the tank doesn't seem to fit any other way. Is this correct?
- Do I need to loosen the air valve on the water tank for the pump to pull water from the tank? Or do I need to keep it tight so that it creates suction?
- How big is the grey water tank?
- I see a standard garden-hose-size hookup under the camper, which seems to be for grey water draining. Is this correct?
Best,
Matt
Matt
Appleton, Wisconsin
2006 Dutchmen T@B ("Fuego")
TV: 2007 Nissan Pathfinder
Appleton, Wisconsin
- May not have city water hook up. Would be on driver side near front.
- Water tank - Spout on top, air cap loose. Gasket between dip tube and pump line - tighten snug.
- No grey tank. Most times, we use a bucket under the drain fitting. There are small portable tanks available. Should be a cap for fitting during travel.
Thanks, rfuss928. Is the "dip tube" a tube that goes from the water to the spout? Sort of like a straw? If so, my tank doesn't seem to have one. That's the thing that's been confusing to me about this setup.Matt
Appleton, Wisconsin
TV: 2007 Nissan Pathfinder0 -
Yes, a long straw that goes to the bottom with a top hat like flange at the top. Keeps it from falling into the tank and mates with the pump line. Gasket for between flanges is seen in top of cap.
2 -
Thanks so much. I was able to assemble something functionally similar out of materials at my local hardware storeMatt
Appleton, Wisconsin
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
