Dust and Water Leak At Front of 2009 T@B 320
Hi All
We have a 2009 T@B 320 Clamshell that has an issue with water and fine dust coming in through the front of the trailer at floor level. The leak occurs when we pull the trailer in the rain or on a gravel road.
I suspect the leak is caused when water or dust is forced through the woven fabric covering the bottom of the trailer. The fabric wraps a couple of inches up across the front to meet the trailer's aluminum panelling.
There is an area about a foot wide, on the right/passenger side of the trailer, that does not have any board behind the fabric to support it - unlike the left/driver side, which has a board or some kind of support, behind it. I suspect I will need to cut, replace and reseal the fabric and well as the support behind it.
Does anyone know where I can find replacement fabric?
Has anyone had a similar issue, and if you did it yourself, how did you fix the problem?
  • kimrvan
    kimrvan Posts: 2
    Here's a picture of where the problem is occurring, and the fabric that will need replacing and resealing.
