FOUND: Mod to lock side windows open (2 position click style circa 2013ish)
AldebaranJill
Member Posts: 480
I found a solution driven by suggestion from @Marceline - a very sturdy double window lock. This enables those of us with windows that click into place to a) lock them into place where they click and b) gives us an infinite range of window openings versus just the two we have now. The only improvement I can think of is if the screws were shorter, but I can always see if ACE Hardware has options if the length bothers me. They can stay in place (secured to upper strut only) and the window closes, which is really awesome. One per window works well, two per window is what I'm going to use because I prefer symmetry.
Photos and links follow:
Link:
Hi All,
I can’t figure this out so need ideas from everyone.Have a 2013 T@B with side windows that push out and have two positions where they stay open. To close, you have to push open further past the detent and then it closes. This is normal operation.
I would like a mod that “locks” the window at either position. Have been in windy conditions where I was worried about them blowing open. Also when I sleep in hotter weather would like to leave them open but prevent casual opening from outside. Or from a dog nose being able to push windows open.
I believe later years have a different mechanism/strut but in looking at photos it doesn’t look retrofitable - but I could be mistaken.
Thanks in advance for ideas!
Jill
Why don’t you give Elsie a quick call and ask if you can swap new latches with your original ones. I love my two position latches!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
Just called, as I suspected, they are totally different and cannot be interchanged.Homebodyatheart said:Why don’t you give Elsie a quick call and ask if you can swap new latches with your original ones. I love my two position latches!
Seattle, WA -> Palm Springs, CA0 -
I don't have immediate access to my trailer so I can't check for myself. But is there anywhere to clamp one of these thumbscrew locks onto the strut that would prevent further opening?
https://www.harneyhardware.com/products/sliding-window-lock-unpolished-mill-finish-34215
Marceline said:I don't have immediate access to my trailer so I can't check for myself. But is there anywhere to clamp one of these thumbscrew locks onto the strut that would prevent further opening?
https://www.harneyhardware.com/products/sliding-window-lock-unpolished-mill-finish-34215Hmm, I have one of those but it would need two, one needs to clamp on either strut (they fit inside each other). But I found this one that has two of them and keys you can remove. Have ordered on Amazon, will know tomorrow. Thanks for idea!
Can you post a picture of what your locks look like?John and Henrietta, Late 2016 T@B S Max in Western New York0
Do you mean what I ordered to test or my window struts?Photomom said:Can you post a picture of what your locks look like?2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
Do you think one/two of these would work to help keep the front window open..?Marceline said:I don't have immediate access to my trailer so I can't check for myself. But is there anywhere to clamp one of these thumbscrew locks onto the strut that would prevent further opening?
https://www.harneyhardware.com/products/sliding-window-lock-unpolished-mill-finish-34215Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
@TerryV6 I don’t have a front window to see the strut but if you post a photo I could offer an opinion. Amazon has an excellent return policy so you could always try it out, low risk.TerryV6 said:Do you think one/two of these would work to help keep the front window open..?2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
You all need 3D printers! Great idea @Marceline and @AldebaranJill!John, Judi, Guinness & OD in PDX
Are those like dot matrix printers? Grin....Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI2 -
Well, the front struts on my Tab are not the fixed positional ones. Rather the outer sleeve has the inner piston go out from it. I cannot see any place to attach one unless I put it near the end, in which case the window will be in a mostly open position. (Most times our locking knob will hold the spot for you if tightened enough, so it is not something that has to be added, )
The clip would go between the black knob and the fastened end..
T@bbey Road
Appleton, WI0
