I'm adding a GPS unit to my trailer to keep track of where we go but I need to get power from an "Ignition On" Source. I was thinking about pulling this from the 12v power supply from the TV. Anyone have suggestions of the best place to "tap" into this? Or a better suggestion of where to pull an "Ignition On" source from the trailer?
0 ·
You might consider tapping the T@B 7-pin running lights circuit and training yourself to always have the TV headlights on when traveling. TV 7-pin connected, TV headlights on, gives you GPS on.
Use any +12VDC T@B source to power your GPS.
Train yourself to Turn the GPS on & off as you travel.
But the problem is how to wire up a circuit that triggers an event when the trailer umbilical is plugged into the tow vehicle. It should be as straightforward as tapping into the trailer battery charging line (the wire that comes from the tow vehicle to charge the battery). As this wire is electrically energized all the time from the trailer battery too, you'll have to add a diode in the circuit so the wire can't "see" the trailer battery but will sense voltage from the tow vehicle when the umbilical is hooked up. There are thousands of diodes with multiple mounting options. A diode for this sort of circuit is also commonly called a "block rectifier". It allows voltage to pass through in one direction (in this case, from the tow vehicle) but blocks current flow from the other (voltage from the trailer battery). The sticky wicket is to find a waterproof block rectifier with two poles that has its own self-contained heat-sink and can handle 30 amps max. This sounds complicated, but is a pretty common, straightforward thing in automotive circuits. There are lots of diodes in automobiles but not many that can handle 30 amps. Most are used for warning lights or feedback loops to the computer and aren't rated for more than a fraction of an amp.
A bit more research is in order here but it's easily do-able...
WilliamA
2017 T@G XL
It would also be possible to add a voltage sensing circuit that would trigger on anything over, say, 12.8V or so. They can be had "off the shelf" with adjustable potentiometers. Could be worth looking into. Such a circuit resides inside the Norcold and most autos that have load-sensing circuitry to protect minimum battery voltage for starting. According to my math, a diode capable of 30A would need to have a heatsink big enough to deal with 14 watts of heat. That's not too large, but it's a waste of an awful lot of power just to avoid turning a switch. If one just had to have the tech, the voltage sensing gizmo would be a better way to do it.
WilliamA
2017 T@G XL
