50 amp vs 30 amp service
Get the adapter and it will send the voltage to the correct pins. That is the one adapter I haven't used. I have it in the tongue box, and I even stayed in a couple of RV parks, but there was always a 30 amp plug also, along with a 20 amp plug also. Sometimes they just advertise the maximum they have.Verna, Columbus, IN
Ditto what Verna said. I've never used my 50-amp adapter because they always have the other plug options on the pedestal, too.Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA0
I have used mine twice. Once there was no 30 or 15 amp outlets on the site. The other the 30 amp was wired wrong but the 50 amp was good. easy fix plug in the adapter and all is well. It is worth having stored somewhere.Norm & Pat. 320 S Outback Utah or somewhere else.
The 50 amp at the pedestal just means that 50 amp is available, your T@B will not use that much. It can't, unless something is wired wrong. Use the right adapter and it will be fine.The HobbiT@B, 2015-L, towed by a2014 RAM C/V0
True, the 50 amp hook-ups are for the BIG GUYS, the 60' gold-plated motor coaches with dryers, ovens and hot tubs, etc.!
As Jandj noted above, your T@B is only wired for 30 amps and adapting (via an adapter) to a 50 amp receptacle will not harm anything, nor will it change the voltage entering your T@B, as you will only receive 110 volts.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Technical question - Since 50-amp is 220v and 30-amp is 110v, does the adapter simply leave one of the 50-amp connections open? Dead slot in the adapter, so to speak?
gerry - Flintstone, GA - 2015 T@B S - 2012 Toyota Highlander0 -
.yep. 50A 220v would be a 4 prong connector, while 30A 110v is three prong.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Yes.... The photo below shows the 50A plug-in prongs and the backside shows the 30A side. The bottom plug entry point (shown below) on the 30A side is the universal or chassis ground and one of the flat pronged plug-in points also accommodates a ground wire. I know it can be confusing (the wiring schemes) but it does work and these adapters come in handy when needed and yet are seldom used.USWildflowers said:Technical question - Since 50-amp is 220v and 30-amp is 110v, does the adapter simply leave one of the 50-amp connections open? Dead slot in the adapter, so to speak?Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
I've actually had to use a 50-30 Amp a few times. I've actually been to 2 campgrounds where the 30 Amp was bad and the 50 Amp worked. And another campground where the 30 Amp was just so overused and loose. My plug wouldn't stay in, so used the adapter on the 50 Amp there too.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
The 50a connector is 240v, and like home it is supplied via two 120v "legs". The adapter simply draws from just one of the legs. You get 240v when both legs are tied together.
I recommend not using the simple kind of adapter pictures above, instead going for a "pigtail" type, so it can hang out of the receptacle box and pedestal easily, and act as a sort of strain relief.
On Amazon:
A_Little_T@b'll_Do_Ya1 -
I actually stayed in a campground in Golden, CO that only had 50amp outlets at each site. They provided adapters if you needed one.
Sterling, VA0
