Bellingham to Glacier, it’s time.
BirdieJane
Member Posts: 237
Any of you going to glacier this week2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn
Safe travels and loads of fun (and some photos)!John, Judi, Guinness & OD in PDX
@BirdieJane, Be safe out there & have fun!
Eric aka: Lone Wolf0 -
@BirdieJane - So glad the Glacier trip included breakfast with the SpoT@b group!!! If was great seeing you again.
2 -
aka BirdieJane towed by Quinn5 -
@BirdieJane, Awesome pictures! So, question of the day...did you catch breakfast?
Wish I could say yes, only fish that got hooked happened when I sat my rod down helping my wife gets stuff ready to cook lunch on the beach. Drug my pole to the waters edge and broke off. The best lake fishing is in Two Medicin but it was to windy all the days we were there.
aka BirdieJane towed by Quinn4 -
With the fires and closures on the west side of the park, what areas did you visit?0
We started the trip on the east side, camping at Two Medicine, then a day trip to Saint Mary to Logan Pass. Then to the Many Glacier area. When We learned Apgar was open we went and set up camp. Very nice, very few campers. We then day tripped to Bowman Lake area. The fire is burning in less then 1% of the Park. Temps ranged from mid 30’s to mid 80’s when the relative humidity dropped the fire activity picked up. Mostly burning in an old burn while we were there. Our last day Shuttel busses began exspress runs from Apgar to Logan Pass. However an inversion had smoke to the ground in the early portion’s of the Going To The Sun road. But we enjoyed the ride anyways.
aka BirdieJane towed by Quinn2 -
Blackfeet Nation
Some really great shots! How did the new Ascent perform on the trip?Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium0 -
How clever with your use of the propane cover & little table on the wheel jack! Don't suppose you have a pic of how you did the table?2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
Here’s @BirdieJane’s post about this wonderful mod!
https://tab-rv.vanillacommunity.com/discussion/5063/outside-hitch-table-kitchen-mod#latest
The Subaru Ascent, is a terrific upgrade from our Subaru Outback 2.5. We really liked the Outback, but always mindful of the hitch weight, and engine temps when climbing in summer weather.
The Acent climbs mountain pass’s with ease. Rpm stay around 3,000 when climbing under tow or without the trailer. Most often we find ourselves needing to watch our speed as you can find yourself at 70 without realizing. We prefer to tow at 60 to 63 mph and keep Rpm around 1,500 when on the flats.
Out trip to Glacier we Averaged 16.3 mpg. This included all types of driving while under tow including multiple mountain passes.
This car has good cargo space, that we filled for this trip as well as traveling with a canoe. We did not do that with the Outback over Hitch capacity concerns. With the Outback we could monitor engine temps when climbing. The Ascent only has a dumb engine temp gauge on the dash. So we where unable to see engine temps when climbing mountain passes. So in closing, we are at just over 4,000 miles and really are glade we upgraded.
aka BirdieJane towed by Quinn3 -
Thanks for finding this old post, I was not that fast. By the way, this table has worked well for tying flies, a stand up bar counter. “we have joked about getting some fold up bar chairs for cocktails”, and a utility table when doing all kinds of stuff
all the items for this are at Lowe’s .2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn0 -
Adventures: 59 Nights: 411 Towing Miles 50,3502 -
How 'bout a meal WHILE you're checkin' out the wildlife!
Thanks for sharing the great pictures! 2016 T@B MAX S-aka: WolfT@B
Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner0
Eric aka: Lone Wolf1 -
@BirdieJane I totally forgot Saturday that you’ve got the Ascent! Argh! Ours comes hopefully Monday! Thanks for the review! I’ll share it with Mr Homebody. Your pics are amazing and I want to get there next year! Thanks!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@BirdieJane I know you have the taller 320 Outback, but what length hitch drop works with the Ascent? Also how many miles on your engine before you started towing? I’ve heard 500 miles before towing but that the engine is otherwise broken in before it leaves the factory. Thanks!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@Homebodyatheart we are using a 6 inch drop. The Subaru Ascent hitch will come with a 5 inch. I feel like we could use a 7” but when we get loaded we seem to level off. You could go with an adjustable hitch. Also check in you glove box or ask where the pigtail is to plug in your brake controller, it comes with the hitch. The car is prewired for a seven way plug and break controller.2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
@Homebodyatheart if your car has RAB (Reverse Asist Backing) it does not like the trailer back there. You can temporarily disable it on you camera screen. But it is slow to turn off. Also if you keep the brake pedal pressure it will not engage and stop the car every time you try to back up. They need an off switch when you tow. Hope they come up with a fix for this.2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
Ok, here comes Mr. Picky! @BirdieJane, you forgot to update your signature line for your new Ascent.
@Homebodyatheart, I'm STILL
, they were parked RIGHT OUTSIDE across the street. Nuff said, time to go scatter joy
& harmony somewhere else!
aka BirdieJane towed by Quinn1 -
@ericnliz Ok profile all updated!!
I'll be right over!
that's just so WRONG showing that big ol' pot of crabs & brewski----you're bad. & I'm jealous2018 Tab 400
- 964 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
