2019 Tab400 Boondock Lite Battery Specifications Question
ColinsTab400
Member Posts: 25
I am wondering if anyone has the battery specifications on the two 6volt 224 amp hour AGM batteries Nucamp is installing? I want to verify the solar charger is set up to maximize the installed batteries. If you have any information on them I would appreciate it.
Thanks
Thanks
@CollinsTab400 When I toured the factory this summer ( uCamp Tour) they were putting in two US Battery 2224. Attached is a spec sheet. Maybe someone on the forum has seen something different since then but that's the best I can offer.
Pam and JohnChamplin, Minnesota2018 T@B400 and a 2025 Ridgeline Trailsport
To answer the OP question, the batteries in my December build TAB400 are model #HBDAGMGC6-A from Harris Batteries. The reserve capacity at 25amps is 450 minutes and at 75 amps is 120 minutes. At 25-deg Celcius, the 20 hour rate is 224 Ah, the 10 hour rate is 194 ah and the 5 hour rate is 179 Ah. With my Lifeline batteries I was told to drop no further than 50% or 11.9 in their case. Harris said 50% is 12.1 volts so FYI.
F150 Pulling 2019 T@B400 BDL -
I use 12 volts as my 50% rule of thumb when monitoring the voltage of my batteries. Good stuff, thanks for sharing!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
