Furnace in my 2007 T@B?
phillipgmolina
Member Posts: 4
This is a little embarrassing, but I don't know if the 2007 T@B we just purchased has a furnace. I do know that it has a Duo-Therm Cool Cat Heat Pump (model 41001.511). The Duo-Therm thermostat control panel has four options: A/C, Off, Heat Pump and Furnace. However, when I slide the lever to Furnace, nothing happens. Initially, I thought it wasn't working. However, reading the instruction manual, regarding furnace operation, it says in parenthesis, "if Furnace is connected to Thermostat." And later, it says, "Furnaces are not Dometic products. Contact your furnace manufacturers service center..." Thus, now I'm beginning to think that it doesn't even have one! Any idea on how I can tell?
We had a Duo-Therm A/C + heat pump in our (new to us) 2006 T@B before I removed it - living in N. Cal. it was not useful, Some buyers elected to not purchase the LPG furnace and only use the heat-pump( very loud). Just look under the seat on the driver's side where it would be installed if you have one. If the furnace has not be turned on in a while, it may need to be checked to make sure it can light when you start the furnace. Our A/C, furnace control have a built in thermostat, but yours may be different if you do not have a LPG furnace. Wishing you many happy trails.Michael & Claudia T@B -Q 2006
San Rafael, CA0 -
Aha. Thank you. Looks like there is nothing under the seat, so it looks like there isn't one. Thank you, meklof! :-)0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
