2019 Tab 400 Froli
JeffroNC
Member Posts: 366
i was trying to find adjustable components for the bed in our 400. I can’t find any pictures at the Froli sites that look the same. Has anybody done anything along these lines?
I weight 100 lbs more than my wife so I need s little more support. :-)
Jeff & Amy
Jeff & Amy
Now in Manistee, MI
Did you check this thread? https://tab-rv.vanillacommunity.com/discussion/comment/111585#Comment_111585John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1 -
@JeffroNC
Does your Froli system look like the attached? If so you (as do I) have the "new & improved" version. It is not adjustable but it is supposed to be lower and firmer than the original version that used to be installed in the TAB 400. It is also cheaper.
That's what we have. I would order a few even firmer units if they were available.
I'll email NuCamp.2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
Jeff & AmyNow in Manistee, MI0 -
I have 18 of the Froli Star elements left over from my 2018 400 I had replaced some of the elements with softer elements for the shoulder area and had added tensioner springs at the hip area I would be more than happy to sell the 18 for $30 plus shipping
2013 Tundra TRD 5.7L
Massachusetts0 -
Do you still have these? I may change all of mine to this type.0
