Lost Hand Crank for 320 -drill socket?
AWlks
AWlks Member Posts: 4
Hello! I'm a new tab 320 owner and somehow managed to lose the hand crank for the stabilizers right out of the box. Of course, we were at the camp site when we realized and used vice grips in the mud 😐. I'd prefer to use a hand drill to lower them and was wondering if anyone new the right type of socket to purchase. Thanks!
  • dragonsdofly
    @AWlks, welcome to the forum and congratulations on your trailer! Sorry to hear about your first bit of trouble, but this is a future campfire story, and we all have them. Some of our experts here will chime in soon with the technical info you need. In the meantime, happy t@bbing! Should we pass you on the road someday, we'll be the crazies waving.
  • dsfdogs
    dsfdogs Member Posts: 641
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
    @AWlks, the Ultra Fab that dsfdogs directed you to fits nicely on a 12 v drill.  That’s all we use anymore.
    @grubbster, does that fit your 320 stabilizers?
  • grubbster
    grubbster Member Posts: 115
    I have a 400 but I assumed these were standard.  Are the 320 stabs different?
    2023 F-150 Powerboost hybrid
    2019 T@B 400 Boondock
    They must be different.  Guess I did not realize that.  Thought they used the same stabilizers on all the TaBs.  So the 400s use a hex drive adapter.
  • ChanW
    ChanW Member Posts: 3,171
    Our '320' uses a 'T' slot type, like that eTrailer UltraFab tool.
    "Back in the day" (2013 ;) ), I cut a slot in a socket that would fit, so we are able to use the standard ⅜" socket-wrench extension (I think it's 12" or so) with our cordless drill. We also have a u-joint flex fitting on the socket, so the operator can be off to the side a bit, instead of straight on.
    It looks as though the UltraFab has a non-standard three-sided 'stem' to fit into your drill chuck, which will work, but negates any option to add an extension. Too bad! An almost complete answer!
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Verna
    Verna Member Posts: 6,876
    The 400’s use a 3/4” socket for the stabilizers. Quick and easy with a cordless drill. I use the same one @grubbster referenced above.
    And, if you change to Dale Helman’s mod to remove the tongue crank and put a 3/4” bolt in its place, then the drill attachment and drill is all you will need.
  • Marceline
    Marceline Member Posts: 1,779
    @AWlks - I hope that we haven't managed to confuse you.
    Since you have a T@B 320 you will need a socket with slot. So disregard the posts regarding sockets for 3/4" Hex Drive Jacks. These are not right for your trailer.
    If you want to use a power drill, you can use:
    https://www.etrailer.com/Accessories_and_Parts/Ultra~Fab_Products/UF48-979071.html (per @dsfdogs)
    https://www.amazon.com/gp/product/B00Q6ISG4M/
  • AWlks
    Thanks everyone! I'm off to Amazon and eTrailers now to check these out. I appreciate the camp story but I don't want a repeat!
  • AWlks
    pthomas745: I ordered the Ultra Fab T-slot bit for my drill but I was just looking at the BAL 23033 hand crank as a back up and wondering if it was compatible with the T@b 320 stabilizers. I guess you've answered that already... thanks.
    It would be nice to have a longer attachment, but the end that attaches to the drill is round and needs a flat edge for the drill to grip.
