Upgraded Shower Head
Has anyone tried the Oxygenics Shower head they sell for RVs at WalMart?
The literature says:
The BodySpa RV is the perfect upgrade. Designed with RV showers in mind, it uses cutting-edge technology that turns even the weakest water pressure into a strong and luxurious spray. At the same time, it uses less water than traditional showers so tanks last longer. It even includes a convenient SmartPause valve that brings water to a trickle. The BodySpa RV also uses the highest quality materials to guard against failure and comes with a never clog warranty. It installs in minutes, so you can be on your way to an amazing RV shower experience in no time.
  • Powerful Oxygenics setting amplifies water pressure and widens coverage
  • SmartPause valve helps preserve tank levels by quickly limiting water flow
  • Designed to achieve maximum performance with tank size and pressure limits
  • Non-stick internal components prevent mineral buildup, clogging and corrosion
  • Limited lifetime performance warranty against failure or clogging
  • Installs in minutes with included plumber's tape
The reviews I've seen seem positive. But, I would like some real life opinions from users.
Gerri (Gary) Ewing
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD
    Had them in several RVs they are excellent. IMHO Well worth the money.
    1. Hash  T@B Fun
  • EmergencyKenEmergencyKen Member Posts: 29
    edited May 2019
    We switched ours over a couple trips ago and couldn’t be happier.    I wouldn’t call it a “strong luxurious spray”, it feels like someone put too much softener in the water.  But we did double our # of showers from 2 to 4 on a tank of water. 6 with an additional 5 gal water supply.
    Cleveland, OH
    2018 Tab 400
    2017 Jeep Cherokee Trailhawk
    Husband, Nurse, Hufflepuff
    Oxygenics Fury is a great shower head. I had one in my T@B S Max, and now I have one in my 400.
  • dsfdogsdsfdogs Member Posts: 631
    I added the Oxygenics Fury also this year and used it twice so far. Yes, better pressure, but definitely not "strong luxurious spray"! Also, it comes with a silly plastic hose and shower head holder. I didn't use either as the metal hose and holder from NuCamp are nicer. I just screwed on the new shower head with a little plumbers tape for good measure.
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
    The Oxygenics Fury conserves water. In my T@B S Max, it actually gave me 4 days of gray water tank capacity, as opposed to 3 days with the stock shower wand.
    I also just used the shower head on the stock metal hose and holder.
  • BogieMeisterBogieMeister Member Posts: 120
    Thanks for the input. It looks like a trip to WalMart is in my future.
    Gerri (Gary) Ewing
  • MarcelineMarceline Member Posts: 1,691
    I think it’s a big improvement. As others mentioned, just replace the head. The original slinky metal hose is better than the hose that comes with the Oxygenics.
    Today I installed the new shower head. Wow, what a difference.
    Gerri (Gary) Ewing
