Cupboards
Bobber
Member Posts: 16
T@B 400. 2018.. My overhead cupboard latches have broken and will fall right out when opened anyone had this problem and if so is there a fix..
I ordered new latches.
I’m in the middle of two other projects, and then I will try to find a different type of latch.Verna, Columbus, IN
Did did you contact NuCamp about it.?
I will at üCamp19.Verna, Columbus, IN
This is my temporary fix for my broken latches till I get home. Elastic hair ties..
@Bobber, thanks for the hair tie solution, but it’s not helping with the one that won’t latch. I’ll try it on the one that won’t stay together. Yes, I have broken 3 this past winter and spring, maybe 4..... I lost track😉Verna, Columbus, IN
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
