The Ghost in the Machine
PJ123
Member Posts: 41
Hi All, perhaps this has been addressed before. If so I'm sorry to bring it up again but... It seems that my Jensen television in my 400 Outback keeps turning itself on. I have turned it off via remote, by the "power" button on the back and have made sure that the entertainment center itself is turned off. The trailer is not plugged in to shore power.
The T.V. responds to all commands and will turn off when the above actions are taken. I haven't checked but once a day after turning off and within twelve hours or so but upon further inspection within that time period ....the T.V. is on.
The 400 is equipped with solar so the power draw is not an issue. The only action I haven't taken is to turn off the battery switch. I don't think I am expected to do so just to keep the television from turning itself on.
Has anyone else had this problem? If so...what was the cure?
I've run this past my dealer (it's under warranty) and he seems as perplexed as I. It would be a shame to change out the television only to have the problem persist.
Any thoughts or insights would be appreciated...
See you around the campfire one of these days....Pete
Pete & Jeanne 2019 T@B red and grey 400 Boondock Lite..TV 2015 Nissan Frontier, Southern Louisiana
Does your tv have a timer setting? Is there an line fuse in one on the lines to the tv you could pop out until you get things figured out? You know, when you’re weary of dinking around with it.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1 -
Yes, I had this exact problem. You accidentally turned on the alarm for the head unit (probably when you set the time), which wakes the head unit up and in turn sends a control signal to the tv to turn on. Turn off the alarm and the problem will go away.PJ123 said:Hi All, perhaps this has been addressed before. If so I'm sorry to bring it up again but... It seems that my Jensen television in my 400 Outback keeps turning itself on. I have turned it off via remote, by the "power" button on the back and have made sure that the entertainment center itself is turned off. The trailer is not plugged in to shore power.The T.V. responds to all commands and will turn off when the above actions are taken. I haven't checked but once a day after turning off and within twelve hours or so but upon further inspection within that time period ....the T.V. is on.The 400 is equipped with solar so the power draw is not an issue. The only action I haven't taken is to turn off the battery switch. I don't think I am expected to do so just to keep the television from turning itself on.Has anyone else had this problem? If so...what was the cure?I've run this past my dealer (it's under warranty) and he seems as perplexed as I. It would be a shame to change out the television only to have the problem persist.Any thoughts or insights would be appreciated...See you around the campfire one of these days....Pete2019 T@B 400 Boondock Lite
2019 Chevy Colorado Z71 Duramax0 -
Thanks JEB outside now to do that very thing..Thanks again!jgram2 No timer setting (that I know of). I check on that when checking on alarm setting. Thanks all !!Pete & Jeanne 2019 T@B red and grey 400 Boondock Lite..TV 2015 Nissan Frontier, Southern Louisiana0
Would plugging in this little switch fix the issue?..
http://tabforum.nucamprv.com/#/discussion/6582/blue-television-light
Hello All! Forty eight hour update here..... Yes, as JEB had suggested the alarm WAS set. After turning off alarm the television has never come on by itself again.Thanks everyone for the input! Hope to see ya around the campfire one day...PetePete & Jeanne 2019 T@B red and grey 400 Boondock Lite..TV 2015 Nissan Frontier, Southern Louisiana1
I unplug my television to avoid the phantom power drain0
