Switch function
Fitzfarm
Member Posts: 6
- We just bought a 2015 T@b max C-CS and love it! However, I can't figure out the function of the black, wall mounted toggle switch just below the air conditioner (next to the thermostat). Can someone enlighten me?
It's an exhaust fan for the air conditioner - you turn it on whenever you run the AC.
Thank you!!!
Glad to help - I'd never had figured that out, my dealer told me.
Yes it is a fan that assists the A/C exchange heat to the outside. With the unit built in, rather than placed in a window, the outside coils need a bit of help to move the heat away from the unit. You will hear it run when you turn the switch on.Martin - Trailer name: James T@Berius Kirk
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
