Noisy Alde 3020
We have a 2018 T@B 320S and recently were camping at 10,500 ft. The Alde heater made noises when it came on all night long . I have read about modifications to the 3010 model but what about the 3020 ? I would appreciate any input anyone has .
Thanks ,
        EvergreenPDR
    Where were  you camping at 10,500 feet?
    I am not sure that the 3020 automatically switches to accommodate elevation.  Don’t you need to go into the Alde display and select High altitude mode?
  • Verna
    Verna Member Posts: 6,876
    You do need to select the high altitude icon that looks like two mountain next to each other.
  • mreric
    mreric Member Posts: 154
    set the 3020 in high altitude mode-
  • pregan
    pregan Member Posts: 7
    Thanks to you all . I will give it a try .
    In answer to pthomas745 we were camping near Leadville , CO .
    MuttonChops Member Posts: 2,085
    For the 3020 High Altitude Mode to function you must activate (turn it on) in the correct sequence.
    The Propane power source must be OFF, select High Altitude, then select (turn on) Propane as your power source.
    Manual Reference
    Also the Display will show that you have turned on one of the special features by lighting (it might flash) the "A" symbol.
