Battery ok, shore power not working.
aholman
Member Posts: 2
MY 2019 T@B Boondock Lite is parked in my driveway with shore power plugged in to my house. Lights, water pump, etc were working fine. Then I went away for 2 weeks on vacation. Now the shore power is not working. The extension cord is lighting up and seems to be working fine, I turned all of the circuit breakers off and then on. Tried unplugging and replugging the extension cord several times. Still no power in the camper.
When I switch to battery power, everything works fine. Anyone have any ideas? There were a number of thunderstorms that may have interrupted power while we were gone. I am wondering if there is a hidden breaker that I don't know about? Any suggestions for trouble shooting?
Thanks for sharing your expertise!
Were you using a surge protector? Are you sure the 110 V outlet is operable? There is a GFCI reset on the outlet under the bed - reset that.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
I'd bet on the GFCI....
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Thank you, T@B friends! It was indeed the GFCI! Everything is working perfectly this morning.0
