What I Did To My T@B Today
We installed bins in the back and it can get pretty dark back there. So I put up a set of four battery powered lights that can be controlled either with a remote, or individually with a switch. We won’t use these for long periods, just to find or adjust something, thus saving the battery life. The lights can be set for different brightness and time on.
It is daytime of course, but here is with lights out...
Lights on..
I got them at Costco for a little over 20 bucks. The only change I made was not to use their metal plate, which fastened to the wood, and the light has a magnet that catches the plate. I didn’t trust the magnet strength. I used 2 small command strips for each light instead, that makes the light easy to remove for battery change. I have a ton of those strips.Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI3 -
Very cool!2018 T@B 400, 2015 F150 tow vehicle.0
I installed a similar light under the AC cabinet.TerryV6 said:We installed bins in the back and it can get pretty dark back there. So I put up a set of four battery powered lights that can be controlled either with a remote, or individually with a switch. We won’t use these for long periods, just to find or adjust something, thus saving the battery life. The lights can be set for different brightness and time on.
Lights on..
I got them at Costco for a little over 20 bucks. The only change I made was not to use their metal plate, which fastened to the wood, and the light has a magnet that catches the plate. I didn’t trust the magnet strength. I used 2 small command strips for each light instead, that makes the light easy to remove for battery change. I have a ton of those strips.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Today I fixed the 3 way fridge with a new quiet fan and thermostat, and added a small Valterra fan to the refrigerator compartment to move air around inside as well. Should keep the fridge more evenly cooled, i.e. no more frozen things in the back corner.
I'm slowly becoming a better plumber, electrician, bearing and brake mechanic, window installer, and HVAC technician than I am an accountant. 😁
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6202
