new Blue tooth thermostat for Cool cat
atlasb
Member Posts: 584
I saw posted about the new thermostat for the Cool Cat heat pump that is Blue tooth capable. Has any one yet installed and how do you like it. Looking for a way to monitor the Cool Cat while away from our 400. usually have the family pet in as it is too hot to leave in the TV while away. Some of the reviews on the net indicate the unit is sensitive to movement with the CT control and some issues pairing with the phone. Looked at the App on google apps and the reviews are only around 2.
Where did you see the thermostat for sale? Does it allow you to move the temperature sensor? Is it compatible with the wiring of the old one?
I saw it mentioned on the forum. I also looked on Amazon & the domestic site. I emailed domestic also & got no reply from them. Reviews are not real good at this point. Seems the capacitive touch is really sensitive. Would like to be able to check the A/C is still running while we are away & our pet is in the RV.2018 T@B 400, 2017 Nissan Titan Crew cab
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
