mysterious tool
kaylevine1
Member Posts: 165
I found this tool on the floor under the table in t@b 400 half shoved under the storage compartment on the right-anybody know what it is for??
Picture, please?Verna, Columbus, IN
If that is a socket on the end it looks like a hand crank for a Ford Model T! Or it might be a crank for the stabilizers and spare tire--before nuCamp started supplying the ratchet type wrench.
Did you recently get a power jack installed? It looks like a manual handle for an electric jack.2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts -
If it is a 3/4” socket, it will fit the stabilizers, but it’s not as long as my 3/4” socket tool is.Verna, Columbus, IN
ok-yes-I just had a power jack installed-it may be for that in case the power stops working-I found it after I got home from picking up at the dealer where it was put on-I haven't looked at the booklet yet
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
