Is there a wood post in this area?
lkc001
Member Posts: 881
Is there a solid wood post/plywood wall between the drivers side kitchen wall & the shower door? There is a small area on the vertical wall between the Jensen stereo and the edge of the shower door that I would like to mount one of those expandable mirrors on & want a solid surface to screw into.
I know there is a wood post on the wall closest to other side of the shower door (where it opens)/wall between the television wall & bathroom, I already have a rotating coat hook hanging there.
Thanks for any info!
2018 Tab 400
anyone?2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
A photo with you pointing to the desired mounting location would be helpful.2016 Outback 320
If you tell NuCamp the location; inches up from counter and back from front wall they might tell you what to expect.
Now I do not know the true wall construction, factory floor build pictures suggest areas of the wall are thicker than others. Try removing the SeeLevel Panel and looking into the wall. Then maybe doing some very small pilot holes to confirm thickness and type of material.Picture From Forward of Water Pump Space.
Picture from Forward of Sink Space.
I will take a picture & post tomorrow2018 Tab 400
Post or not, it looks to me like that wall is solid 3/4" plywood. That is certainly the case for the adjacent wall that is behind the toilet, which I have cut a large hole in.The plywood should be plenty secure for hanging most anything, though you do have to be careful not to poke through to the other side!2015 T@B Max S (320)
Here is a pic-- between the two purple sticky arrows is where I would like to mount the expandable mirror, then secure it with a bungee or something for travel so it doesn't swing around.
2018 Tab 400
Been out to the T@B and did a little investigating while there. The wall itself (at least on mine--2015-S) is closer to 2" think, so it's more than just a sheet of plywood.Some strategic tapping suggests that the kitchen side is solid plywood, but much of the bath side is just a thin sheet of something with hollow space behind. However, it does feel like there is a solid piece running the entire height of the shower door. Makes sense, since the shower door would need something solid to attach to. The upper cabinets would also need solid mounting, so I suspect that are would be even further reinforced.Not a definitive answer, I realize, but I think you've got plenty of meat to attach to in the area you indicate.2015 T@B Max S (320)
Good question. I'm not certain but on mine I think they run behind the shower and up along the front wall of the trailer in the zone behind the toilet. I don't think anything runs through the ceiling, as there is no cavity to speak of up there.Here's a generic photo showing the bulk of the wiring:
That area should have at least the 3/4" plywood on the kitchen side. Also, if you take out the Jensen (only four screws on the face), you'll see the wires run down near the front of that wall. You should be fine putting the mirror there.2016 Outback 320
- 424 Service/Maintenance & Recall Notices
