Changing Tire
After reading several comments here, I decided to check to see if my car tool would fit the lug nuts on my trailer wheels before taking off on our first trip...it did not.  We own a 2017 T@B 320S...any suggestions on the best tool to use to remove the lug nuts and the size of the lug nuts?
2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
  • wooper
    wooper Member Posts: 75
    Thanks...that tool look like what I needed.
  • MiquelCamo
    MiquelCamo Member Posts: 91
    They are 3/4". I carry a 1/2" breaker bar and a 3/4" socket. The tool linked above should do the job.
    Mike and Lisa Campbell
    Springfield, MO
  • tabiphile
    tabiphile Member Posts: 472
    edited August 2019
    You should carry a breaker bar and sockets for removing the nuts and a use a torque wrench to replace them.
    If you use a tool that does not provide a torque reading to install the lugs the safe thing would be to stop at a garage to make sure that you have tightened to the recommended torque. Pay attention to the tightening sequence and stop after 100 miles to re-check the torque.
    https://www.harborfreight.com/hand-tools/sockets-ratchets/breaker-bars.html
    https://www.harborfreight.com/search?q=torque%20wrench
    Or Amazon if that's your thing.
    If you have locking lugs, think through your plan if the key gets lost or stripped.
  • rcuomo
    rcuomo Member Posts: 321
    I have a 2018 320S with the alloy wheels. I contacted the wheel manufacturer September 2017 and they advised me the torque specs were minimum 90#, maximum 95#. I will post the email if I find it.
    Huntington LI
  • 4ncar
    4ncar Member Posts: 1,072
    Just as others have stated, I carry a 1/2 drive breaker bar. But I carry a full complement of sockets, so the 3/4 just happens to be in the mix. I’m a firm believer that an item should never have a single purpose.
  • JP2558
    JP2558 Member Posts: 248
    My 320 is 3/4 on the wheels. I got a four size, x/cross bar lug wrench at Harbor Freight for $10.00. As soon as i move my spare to the tongue, it too will have 3/4 inch bolts too. (Bolts on the darn spare are rusted - after two years, and I have been trying for four days to break them loose.)
    Thanks, Jerry
  • tabiphile
    Spray the lugs with PB Blaster and allow them to sit overnight before trying to remove them using a breaker bar. You may need to add a piece of pipe to the breaker bar to get more torque. They should come right off.
  • JP2558
    Thanks Tabiphile, I will give the PB Blaster a try.
    Thanks, Jerry
  • Marco
    Marco Member Posts: 18
    I went to Harbor freight too and paid 10$. Its got 3 or 4 sizes.
