Battery Hookup 2016 Outback
NYRichard
Member Posts: 6
Hi,I have a 2016 Outback I want to get on the road. I have no manuals or experience. I need to install a battery but have only the lead wire cable with a red and a black lead (cut off beneath propane and battery enclosure). I do not see any battery cutoff switch. Can you advise on wha t I need for type of battery, inline fuse? (Assume red is hot), battery hookups, etc. Thanks!
Sorry, red and white cable leads, no black.0
Not sure if you have the solar port on the driver side of the tub, but if you do, the the red is positive and the white is negative.
If only the battery, nuCamp uses a green wired fuse holder connected to a red lead for the positive and a white lead for the negative. Use a 30 amp fuse. I have attached Fuses for Newbies and a schematic that may be helpful. There are also pictures of the junction box wiring (under the front of the TaB) if you need that.
https://us.v-cdn.net/5021717/uploads/editor/f9/h7rtaavl6g7x.pdf
https://us.v-cdn.net/5021717/uploads/editor/q4/kuwppa7w77ab.pdf
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Battery cutoff switches were not installed on the 2016's.2016 Outback 320
2024 Ford F150 Supercrew short bed.2
- 964 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
