Lug Nut Wrench Recommendation
JP2558
Member Posts: 248
Can anyone recommend a decent lug nut wrench for a T@B 320-CS with 14 inch tires? Thanks!
Thanks, Jerry
I bought a Powerbuilt Billy Club Lug Wrench2019 T@B 400 Boondock Lite0
@JP2558, we use a folding 4 way, with various sizes, so another of the 4 way sizes fits the tv. DH believes the correct socket size is 3/4 of an inch for the t@b.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
3/4 socket & a breaker bar. All part of my on board tool ket.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
I use the Dorman 711-900 AutoGrade Lug Wrench (previously recommended by @Verna). It includes: 17mm, 3/4” (19mm), 13/16” and 7/8” deep well sockets (two sockets with different size on each end.) The handle is 16” long and each socket is 3” long. Includes a carrying case. Has worked well for me.
https://www.amazon.com/gp/product/B004SEXO3E/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Greg & Marlene (Tucson, AZ)3 -
I use standard 4 way lug wrench, 3/4 end for T@b lugs, picked up at Walmart for $11. I gives me better grip. I don’t like folding ones because they seem to break when I’m depending on them.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
Thanks everyone for the input. We truly appreciate it!
Next question: Torque wrench recommendations?
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.0 -
@JP2558, I purchased this one.......really well made and works great. Just used it this morning.
https://www.amazon.com/gp/product/B00C5ZL1NS/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
Thanks Bayliss - what is the recommended torque for a 320-CS with 14 inch tires?
Thanks, Jerry
I have never in my life used a torque wrench on lug nuts. This includes my cars, trucks, trailers, off-road vehicles and my race cars. Never had a wheel come off yet, and don’t expect. Edit: at home I have air impact to put lugnuts on. On the road, breaker bar is plenty, until I get home.tabiphile said:
And a torque wrench! I would not put lug nuts on anything without one. Lug nuts must be properly torqued and rechecked after a hundred miles or so.4ncar said:3/4 socket & a breaker bar. All part of my on board tool ket.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback2 -
@JP2558, I do not know what the recommend torque is for the 14" wheels, but it is 95 lbs for the 15" boondock wheel. I completely agree with @tabiphile. You DO want to check the torque, especially after removing the wheels (e.g., tire rotation, bearings re-greased, tire change, etc.) When the tires are rotated/changed, even if torqued by the shop that rotated/changed your tires, check the torque again after about 10-25 miles, and again around 100 miles to be sure they are properly torqued. While on a trip, I re-check the torque occasionally.
Greg & Marlene (Tucson, AZ)1 -
The factory torque wrench recommendation is 90 lbs for a non-Boondock/Outback model.JP2558 said:Thanks everyone for the input. We truly appreciate it!
Next question: Torque wrench recommendations?Verna, Columbus, IN
@Verna, thanks! Was kinda wondering just for my personal knowledge.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.1 -
Torque Wrench?? Same here. Never used one, have similiar "resume" as yours. When I was having truck tires rotated at tire shop(I have lifetime rotate balance), I mentioned this and the techs laughed.4ncar said:
And a torque wrench! I would not put lug nuts on anything without one. Lug nuts must be properly torqued and rechecked after a hundred miles or so.4ncar said:3/4 socket & a breaker bar. All part of my on board tool ket.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
They laughed because they know your rotors will warp and that you'll be back for a brake job...
Seriously, any advice not to torque based upon anecdotal experience should be ignored. Any good professional and or shop is either hand tightening with a torque wrench or using torque sticks with impact. Stay away from any shop that does otherwise.
Here are a few links that relate:
https://www.brakepartsinc.com/dam/jcr:e3d06f2b-a4c2-4cf5-b976-822b9133e3e5/Torquing%20Lug%20Nuts.pdf
https://info.kaltire.com/why-re-torque-the-importance-of-retorquing/
https://www.bauerbuilt.com/About/Blog/articleid/74/retorquing-lug-nuts-after-you%E2%80%99ve-had-your-tires-replaced-or-removed-is-crucial
Hmmmph...I've never drowned but I learned how to swim.0 -
@tabiphile rotor warping will occur with Over torquing the lug nuts. 90 ft/lbs is easy to achieve, if you torque to 100 or 110 no harm no foul. 150 ok, but believe unless your hulk hogan you won’t be putting 150 ft/lbs of torque while your on the side of the road. If you don’t know how to use your tools for a road side emergency, then call AAA.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1
- 968 Air Conditioning & Refrigeration
