Jensen TV won’t come on
320-S 2020. Got a campground with cable TV. Hooked up coaxial to rig. Hooked up to shore power, battery also on and charged.  Hit Power on TV, nothing. Just a blue light on. Tried every button on remote as well - nothing. Maybe I have a bad TV.
    pthomas745 Administrator, Moderator Posts: 4,684
    edited September 2019
    Ahh, the Jensens.  What is odd:  the blue light means it is off or in standby.  Press the power button on the TV itself.   Blue light will disappear, and the TV is "On".  Something should show up on the screen.
    That is what happens on my TV, at least.  My remote:  press the "TV" button, then the "power" button.
    Then you have to select the Source....and scan for channels.
  • [Deleted User]
    [Deleted User] Posts: 92
    Solved. My battery had completely run down yesterday and I had to recharge. Apparently when that happens you have to unplug your TV from the back and plug it back in to reset it.  Then it will power up. Who knew!
  • [Deleted User]
    Thanks!
