Jensen TV won’t come on
[Deleted User]
320-S 2020. Got a campground with cable TV. Hooked up coaxial to rig. Hooked up to shore power, battery also on and charged. Hit Power on TV, nothing. Just a blue light on. Tried every button on remote as well - nothing. Maybe I have a bad TV.
Ahh, the Jensens. What is odd: the blue light means it is off or in standby. Press the power button on the TV itself. Blue light will disappear, and the TV is "On". Something should show up on the screen.That is what happens on my TV, at least. My remote: press the "TV" button, then the "power" button.Then you have to select the Source....and scan for channels.
Towed by 2014 Touareg TDi -
Solved. My battery had completely run down yesterday and I had to recharge. Apparently when that happens you have to unplug your TV from the back and plug it back in to reset it. Then it will power up. Who knew!
Thanks!
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
