Clam shell Kitchen Leaks
CCPICC
CCPICC Member Posts: 43
For anyone who has an older clam shell when it rains heavy my kitchen used to leak and get water all over the place. I was at a RV show where Little guy had their tiny trailers on display and they had a special piece made of high density rubber that covered the hinge crack and kept water out. I called them and asked if this could be used on the T@B and come to find out that it could, so I ordered it and installed it and I haven't had a leak since. You may want to add this to your clam shell model as a great accessory.
  • Verna
    Verna Member Posts: 6,876
    That's great to know. Thanks for the info.
  • SunnyTAB
    SunnyTAB Member Posts: 65
    Great to know though we haven't had any leaks.
    Tiff in Seattle
    2012 BMW x3/2008 TCS "Sunny"
  • Mouseketab
    Mouseketab Member Posts: 1,262
    I was one of the first ones to add that rubber to my Clamshell hatch, although I bought the rubber myself and had my local dealer install it
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • Michigan_Mike
    edited May 2015
    If the above cover ever develops a leak, shoot a little caulk in at both ends as this is what they did down at the Sugar Creek factory to eliminate any water migrating in and down the galley hatch edge.
